ChuenouXiao
That will fit into my stock battery compartment with no mod? Something in a 5000MAH range?
You might want to consider a lipo receiver pack. It wakes up those servos.ChuenouXiao said:That will fit into my stock battery compartment with no mod? Something in a 5000MAH range?
I don't mind the extra punch to my servos but I think these you listed are good enough for me DelugeDeluge said:
I have read that that some have ran the 645 and the 5755 on 7.4 volts. I'm not sure how long they would last. You don't want to run a regulator because then the servos only get the 6 volts. It's the higher voltage that gives the punch.Not be rude and jump in on someones thread but what is needed to convert over to Li-Po or Life-Po. Wanting to convert over to get better response on my servos.
Yeah, I'm not quite ready to kick NiMH's to the curb. They get the job done.ChuenouXiao said:I don't mind the extra punch to my servos but I think these you listed are good enough for me DelugeBesides.... I don't have any special lipo charger if I was to get those high performance battery pack
What is up with those battery packs from RC killer?
