Best tires for snow/ice track
MadMax
Moscow
I'm thinking what tires to buy for winter racing for my MCD v4. The track is snow, crumpled snow and ice. So i have few variants
1
http://www.largescalerc.com/4737-dirtbusterblocktirescompoundonblackwheel.aspx This tires were good last winter, but may be there are another variants ?
2
http://www.largescalerc.com/4789-dirtbusterblocktirehdcompoundonblackwheel.aspx
This is the same tires but HD compound. HD compound or S compound means the stiffness of the inner foam or the stiffness of the tire ?
And two GRP wheels
3
http://www.mogatech.de/shop/1-5-BAJA-HPI-MCD-RR-BULDOG-A-Soft-Glued-on-Dish-Wheel-White_1
4
http://www.mogatech.de/shop/1-5-BAJA-HPI-MCD-RR-BULDOG-B-Medium-Glued-on-Dish-Wheel-White_1
I think BULDOG wheels can be good on this type of the track.
I'm searching for the variants, because i tried MCD block & micro stud white sport, micro stud ultra grip and they have much less traction, than the 1 variant (HPI dirt buster s compound (4 rear wheels)) on snow, crumpled snow, ice
May be block stud ultra grip tires will be good ?
For the Spring, Summer, Autumn micro stud ultra grip are definitely one of the best... but not for winter...
And the wheels must be at least 160mm, because i need good ground clearance
So what do you think about this ? Any good variants, please ?
Thanks
Max
see if hostile mxt's front all back for the baja would be the right size on all 4, then put screw studds in them , will work way better than what you are posting....
Thanks, guys, really nice ideas here. But i need wheels to race on competitions.
