Ok you went true diy hybrid/ losi baja style.. @dougstar send em that pdf of the baja compatibility list brother..??Losi front Baja rear
I noticed you were running the black and you have them screwed half way down and your rear end is lighter than mine
The Baja shocks are taller
Can do if you keen??Ok you went true diy hybrid/ losi baja style.. @dougstar send em that pdf of the baja compatibility list brother..??
I know there are extenders for the losi shocks to fit the Baja rear but haven’t seen anything about losi springs on Baja shocksPersonally I'd get the losi spring the whole way around. Think john parks had mentioned some sort of extenders for them to fit up to a baja rear. Keep it simple.
Ok, I got you in the beginning that was my original plan but I could win jack on eBay at the time so I went the irc route I f I remember I think you were bidding on some stuff also for your losi. I remember you winning 1 shock I believeLosi springs are too big, I was saying I'd use the losi shocks at all 4 corners, keeps the rebuild kits to a minimum and one type if you know what I mean
Here i am quoting myself...I'm with @blackrain the rear end sags like crazy.I ran 5t rears on all 4 corners of my build.
Still didn't get keep the ass from dragging lolI was going to ask you about that saw your pictures on Facebook your shock preload was turned almost all the way down.
