Boost Bottle Vs Juice Box.
i put the boost bottles on mine and love it.****HOW BOOST BOTTLES WORK **** Adding a boost bottle kit to your engine is one of the most cost effective upgrades out there. It is designed to expand your intake area on your engine by storing atomized fuel molecules in its chamber and forcing them into your engine while you are off and on the throttle. This bottle provides a "Boost" or supercharge effect.As the engine (any engine) draws fuel and air in through the carb on the intake cycle, the spark plug fires this mixture forcing the piston down and sucks a small amount of air into the carburetor for the next intake cycle. As the piston and crank bottom’s out on the bottom of the cylinder, the piston begins to make its return upward. As this cycle is happening, the piston pushes air back through the carburetor naturally under pressure. This action creates a reverb effect and causes the air / fuel mix to become double rich as by now it is processed TWICE by your carbs fuel jets. Most commonly, this results in rough idle, hesitation, bogging, and the ever-so- frustrating: Sputtering at top end. The reason the sputtering and bogging is happening is because of the double rich mixture. Heavy exhaust smoke, heavy engine loading is often looked at as too much oil / fuel ratio, bad carburetor, etc. While this may be one of those problems, it often is not. Your engine is actually choking itself out with a bad fuel mix! The installation of our Boost Induction Systems™ Boost bottles eliminates this nagging problem. (Hence the location of the inlet) The metering Syste automatically adjusts itself to work with your engines compression and carburetor. Our bottles will eliminate the reverb caused by your pistons return to top dead center (TDC) and remove the double mix! Now, with the bottle installed, operators are now no longer fooled by the double rich mix. This now allows proper adjustability of the carburetor! Tired of sacrificing top end speed for low end? Or low end speed for high? That’s because you have either a double lean mix or a double rich mix. (Rich for high end, low for low end)You cannot have one or the other without a proper intake booster (Boost bottle). The bottles will provide a “Boost” or “Supercharge” effect. It will even out the double mix (either lean or rich) and allow your engine to idle 3–4 times smoother and decrease your engines vibration on your motor mounts, and more! Once your boost bottle is mounted on your engine, please do not remove it. It will outlast the life of your engine and only operate better.
/monthly_2008_08/P6250005.jpg.2d40ebe1f54a19eef41a6fc0a2f815b3.jpg
/monthly_2008_08/P6250001.jpg.4a9dd43f39f9f17de5362fbea3d5d88e.jpg
The question is whey the Air/Fuel mixture wants to go into the small holes to the bottles rater than the big space of the carburetor??
The presser in the filter most likely will be more neutral because it is open from the filter side to the atmosphere.
Can you explain pleas?
