Timduli
- kvassåsveien 22, 4380 hauge i dalane
hmm i couldent find any tread's about it, but i was thinking of drilling it maybe, and making it a 6mm, that should never break imo. has anyone tryed this?thats a common problem mate with the hpi baja line of cars theres a good thread on here about solving this i think its,,,,hpi pinion bolt mod,,,search through the hpi baja threads im sure you will find it,,i only run fg's so thats all i know on the baja's other than i want one
don't think you have enough metal to drill and re-tap
if your able to back out that broken screw or if you can cut a notch in it to grab it with a flat screw driver, and do that reverse screw mod from inside of the bell,if you manage to get the screw out and do the screw mod, double nut it the nyloc plastic/nylon locking material will melt with the heat and drip out,and the nut will come loose
