ThxLength is 1 1/2"
Rough OD is 1 3/4 or just a tad smaller (used tape measure)
Well no but my concept is the same if you were gonna make ur own. So this is how in doing it. Buy a velocity stack, $7. You already have your own carb bolts so those aren't needed, you'll have to find the tube but they aren't that expensive, I got mine for $6, dt1 air filter $20, air filter outerwears $22, you could make ur own if you want, 3x hose clamps, approx $4, and the little metal tube for the filter, i got mine for $8. So the total would be like $68. That's if you don't have a filter and don't have outerwears. So if you had your own filter, velocity stack and outerwears it would be a good savings. I only needed the $6 tube and $8 metal air filter tube thing, so I ended up spending only $14. Keep in mind, I own a Baja not a losi so prices may be a little different for you.Are you making your own version? I'm interested haha, the price is pretty steep for the stu!
mine already had a 45 degree bend, you might need more for a losi though. id ask ddm or someone on here what the angle on the bend is on the crazy stu intake, through the screen it looks like maybe they took a 180 degree bent tube and cut it in slightly after the bend. heres picsHow are you making the bend Z?
take pics when u get the parts and make it plz!Thanks for the help. I have order parts to assemble one myslef!
mine was from ebay . this is the one i bought, don't think it would work for a 5t tho https://www.ebay.com/itm/1-75-45mm-45-Degree-ELBOW-TURBO-INTAKE-SILICONE-COUPLER-HOSE-BLACK-2X-T-CLAMP/163691587043?hash=item261cc765e3:g:ROkAAOSwLvpc3Jx4&enc=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&checksum=1636915870434f367ecf85534141a5b239fe9bda0f38Will do! Did you order the silicone hose online? I'm looking for a good website to order from
Do you need to put something inside the tube so it doesn't collapse?This is Hella late lmaoo
But you can actually dip the tube in hot oil. Like a clean deep frier, and bend the hose. Cool off in colddd water immediately after. I use to work at a company that did a more sophisticated version of that with pvc and other plastic tubing. Just adjust the temp of the oil to suitable for the material and voila
