What's a good carb to switch to and a better air filter for the rampage mt
It says it's a 32ccAre you having issues with your stock carb?
If your truck came with a 30cc engine your option for stock like carb will be a Walbro 668.
If you are comfortable with chokeless carbs, then the Walbro 990. Some are having start up issues with it some don't. I personally never had any and it's a definite upgrade to the redcat stocker or Walbro 668 in my humble opinion.
If your truck came with a 32cc engine then your upgrade option is the Walbro 1102 (it has a choke).
I've never used the 1102 with a less than 32cc engine, so I don't know how it would perform with such engines.
Check this thread for other opinion.
As for air filter you can't beat the stock Baja 5B one.
If you read the specs a 990 is just a 668 with no choke.Are you having issues with your stock carb?
I just went with the walbro wt-1107 and it’s been working great
I THINK the starting point is 1 + 1/2 low and 1+7/8 highWhat did you set your high and low needles to for optimal tuning on the 1107?
