carb settings
thanks 4 the info,I guess i have a different problem. Will not start. Good compresion, have know idea whats wrong, any help would be great:confused:
well how are you judging compression for one...and a few things to check....are you getting good spark, is your engine getting fuel, is ur air filter clean enough to let air through. it could be a number of things but i would start with those. and if none of them are the problem i guess we can try to help from there
Got the right mixture? Fuel in the primer bulb? Fuel inlet goes to bottom of carb, return comes from primer bulb. Got spark?
