Carbon diff brace? yes or no?
Timmahh
Bajastafarian Madnes
PLUS member
Michigan
GOOD Carbon is a Rock. don't know about that perticular item. but if carbon is done right, it should be stronger stiffer and lighter than an aluminum counter part, but when you over do carbon it can/will brake, but Aluminum Bends! and needs to be Bent Back.
for 13.00 us id say your not out anything really if its poop.
T
Jonny
Stoke on Trent
Hi Timmahh,
I think i may try the carbon one, hopefully its good and it also looks the part!
off topic but do you know of any websites with tips on weight reducing an FG? There was one when i had a savage call diet savage and it helped me drop my sav weight ALOT.
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
I have never had a Dif brace break or bend but it does wear out at the screw holes. If carbon can handle the movement of a fastener head vibrating back and forth then it should be no problem. I would make sure to crank it down and use a sealant to secure the head from being able to vibrate loose. Either way it should be OK.
Good luck.
BTB.
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
I thought you got the diff brace too? Is the tray as good as you would think aluminum would be? I was thinking of the carbon one instead of alloy when I get around to upgrading.
WoodiE
Kind of good admin.
Community Leader
Kentucky
FG Hopups has an aluminum servo tray, however there is a company that sells an aluminum servo tray that is black and looks pretty sweet - but I can't find a link for that.
-Michael
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
-Michael
It doesn't look like there is a way to install the third servo on fg-hopups? Wonder if he has a different one that would work for front brakes?
The second sites doesn't look like the throttle or break servo has holes in front for fastening?
