carburetor cleaner
umeshg
LSF Plus Member
PLUS member
North London
Can I use the normal carburetor cleaner liquids or are there any special sprays cans for 2 Stroke RC car engines
Thank you as ever
Thank you as ever
No not recommended as you'll destroy any oil seals, orings and gaskets
Troy
You can if doing a carb rebuild. if doing to just clean it, you run a slight risk of degrading the rubber of the orings. I have never seen it happen, but there is the risk. I use electrical contact cleaner it clean my motor and carb off after a hard weekend bashing.
Thanks. Which make do you use for electrical contact cleaner i
He was referring to the motor and not a carbie rebuild and would be better off using a engine degreaser or heavy duty engine detergent to clean a motor
