Imran Hussain
- stockport
Hi
Can someone help me please my car won't run needles are factory new plug keeps flooding. The problem I'm having is each time it gets flooded I turn it over pull the start 10 times leave it overnight next day I'll pull start few times put the plug in couple of pulls and it starts but I have to hold the throttle to keep it going once I let go it dies and it's impossible to fire it up again, this has happened every time I start it up over the last 10 days. Problem started when I had to repair the pull start and hadn't started it for a couple of weeks prior to that it was running fine. New plug has got spark good compression as it fires up then dies and it's not that easy to pull u can feel the compression if you know what I mean. Needles factory settings. Please help, can't test for air leak around carb cos it won't idle. Tried leaning the LS needle same problem just won't run without giving it some throttle and even with that it's bogging.
Thanks
Thanks
