- Minnesota
I'm sure I've seen a post somewhere on this but what do you guys think this one will be like? Sound bad for $1200.00 rtr? And what is a 27cm3 engine?
Technical data and content of delivery:
4 mm aluminum chassis plate with countersunk bolts
3 differentials
shaft drive
6 mm shock stay
all gears made of steel
independently adjustable disk brakes for front and rear
adjustable servo saver
giant oil filled shocks (30mm diameter shock body, 6mm diameter piston rod)
Aluminum front uprights
turnbuckles for toe-in/out and camber adjustement
fully ballraced
epoxy brake disks
700cc fuel tank with filter and ventilation
splash protected box for receiver and rx-battery
side mounted rocker panels for protection against dirt and gravel
gear protector
27 cm³ Carson CY engine
length 770mm
width 545mm
Content of delivery:
RTR model, factory built with 40 MHz FM rc-system already installed. Two strong servos, 6 volt rx nicad pack with charger, line breaker and 8 alkalines for the transmitter are included. Tires are mounted and glued.
http://www.rc-car-online.de/carson_neu_2007.php#1
3 differentials
shaft drive
6 mm shock stay
fully ballraced
epoxy brake disks
gear protector
length 770mm
width 545mm
