Draggline53
- macomb mi
Hi guy's, does anyone have any info on the cat5-34cc race ported and modified stroker zenoah engine. Looks interesting however I can't find any reviews or videos that makes me leery!
No. did not have a problem with the ropes. It is important not to pull the rope many times quikly. If you go on the OBR side , and look their engine tuning video. The explain what is the correct way to start. You have to slowly bring the piston to a position and then pul to start. And do it one pull at the time.Have you had problems with your pull starter on w5 sct. Heard the ropes brakes...
Sounds good what do you mean by bake motor? Did it over heat?
Like to see video of w5 running. Installing servos this week for my mcd rr5. Just ordered alloy gear carrier from Germany. Will b a bartolone pipe from LargeScaleRC. Good info on the cat 5!!!. Going to purchase w5 sct next month with the bartolone. Did you have to cut hole on the side to modify bart?
I had a Cat5 in my hand this past weekend at the Fall Brawl race, and I can tell you it is the highest compression engine that I know of on the market.
With that being said, the reason people are having the pull rope and starter pawl issue, is the technique they are using to pull the engines over.
This one will definitely require you to slowing pull until the pawl is fully engeged into the flywheel before pulling to attempt to start the engine.
If your chose not to do this, the Extremely high compression will be a problem for your technique, and the combo will lead to broken pieces that could be avoided.
On the track they did extremely well.
Most tracks are made up of shorter straights & corners, and this is definitely where the higher compression helps out.
Big torque of out of the high compression Cat5 engine, and this allows quicker acceleration, and faster throttle response times when cornering.
I would Highly recommend this engine to anyone looking for Big torque, especially those who already tend to run a high octane racing fuel.
The one modification that I was made aware of by the builder of Cat5 engines, is that the extended stroke raises the piston in the cylinder.
Most add a gasket to allow for squish clearance in the top end, but not on these ...
The piston is actually machined to match the hemi combustion chamber, allowing for the higher compression, without changing port timing by adding base gasket thickness.
To me this is one cool addition, which is a signature of the Cat5 brand of engines.
Erutw5, I did not personally get to see your engine, but I do know it is being worked on, if not already finished.
I would adjust your low needle closer to 1 1/4 and adjust the idle if needed.
By keeping the high needle around the 1 5/8 mark you should always be safe.
1 3/4 on the high end is very possibly why you are fouling spark plugs.
I personally keep my engines usually within about 1/16 tune from 1 1/4 Low & 1 5/8 High, and have Never had a lean seize Ever.
Keep your oil mix at 25:1 which will be basically 5 oz of oil per gallon of fuel.
These engines do not require much tuning at all.
They are pretty much set it & forget it.
Always nice to have it a bit on the rich side, to keep safe from issues, if you question.
If the engine runs a bit strange when cool with a " normal " tune, run it until fully warm before judging.
Once the heat comes up in the engine, the engine will come around, and burn the fuel in a proper manner.
I have ran a Ton of engines in a Ton of different conditions, and I would have to say that the tune is very important, as well as keeping the air intakes, flywheel, & cooling fins free from debris.
With a " Normal " tune, clean cooling system, and proper fuel to oil mix, you should remain safe.
