Chengqi Baja Buggy
mwr50
New Member
I have the Chengqi Baja, I know its a copy of the HPI.
I am having problems starting it, it has started without any problems, but had not been run for a month and now I can't get anything from it, there is a spark at the plug and fuel there when I prime it. Anybody got any suggestions?
Welcome to the forum. Is there fuel getting into the engine??? I know you said it primes but is that fuel getting past the primer bulb? Wet Spark plug? Try replacing the spark plug. If the plug is wet then leave the plug out for 24 hours to allow the motor to dry out. Replace with new plug and try again.
If that isn't the problem you may have a more serious issue
Baja Buggy starting problem
Thanks for the suggestions, I'll look at that.
Mike
