- Nj
In worst case you could always notch the lower portion of the stinger to clear the turnbuckle
Atleast with that you have infinite adjustment for the pipe height if you use a nut under the pipe bracket then one on top so then you can jam nut it rather than stack washers and be off the mark that you want.Ill take measurements and see if i can locate a slightly larger one.
Bam found some and ordered them. Roughly 3/16 taller. Same threads and they are air compressor, gasoline motor approved.
Then the issue you run into there is running out of threads. Thats why i just went with taller ones.Atleast with that you have infinite adjustment for the pipe height if you use a nut under the pipe bracket then one on top so then you can jam nut it rather than stack washers and be off the mark that you want.
@Mick Boomer this one.
