Clutch 8mm holes and 10mm holes
andriesb
Boksburg
Hi All
Can i use the 10mm hole clutch(Baja 5b) on the Zenoah 26cc engine with the bolts that fit the 10mm holes.I have put the clutch (10mm holes) in my FG MT with the 8mm bolts but it doesn't work.
If you are going to swap from CY - Zen you need the mounting plate, one mounting screw that goes in the end of the crank shaft, two normal washers, two spring washers & two bolts that mount the shoes.
no don't need the plate, just the clutch shoe shoulder bolts. the threads are the same adn teh bolts are the same depth, its just the "shoulder" area on each is the differance.
so if you use a cy clutch, then you need cy shoulder bolts.
if a zen clutch, then zen shoulder bolts.
I don't think the washers fit as the hole in the middle of them is a different size.
For some reason I thought the plate was different..... I know one has a counter sunk screw holding it in (CY) and the other (Zen) uses a hex head.
