Hello to all, I finish putting ddm pipe to my MT and wanted to know if this
model PIPE is compatible with Wheelie Bar FG.
[/IMG]![]()
I hope that podais to help me and to excuse me badly by my ingles.
A greeting.
Hi Rob.
First of all, you need to order the MT uprights that bolt onto shock tower as the Hummer kits don't offer a mount for the top of the wheelie bar.
Secondly, the rear diff key you have mounted will not let you bolt on the wheelie bar as you need to get to those 3 holes at the rear... I suggest removing that diff key as that would only serve purpose if you had reverse due to the rotation direction of the diff.
Thirdly, the pipe will burn the whellie bar slightly as the pipe outlet aims right on the bracket... this can be avoided by extending the alloy tube by 20mm or 3/4 inch.
Hope that answers all your questions.
