Grinding that little bit out of the bulkhead won't make a big difference. But the rcmax alu pieces are so much nicer ?
Crazy. That would be a complete hack job there?? That was just the preliminary markings for cuts. Who knows how far it would need to go to make it fit. It was either send it back or get the rest of the rcmax azz end.Grinding that little bit out of the bulkhead won't make a big difference. But the rcmax alu pieces are so much nicer ?
YupSweet now it will all fit 100%??
It's definitely a hack job and looks like poop. But I don't think it would weaken it enough for it to be an issue. Either way, it's gunna be a sexy ass on this Baja ??Crazy. That would be a complete hack job there?? That was just the preliminary markings for cuts. Who knows how far it would need to go to make it fit. It was either send it back or get the rest of the rcmax azz end.
Yup
? I just cant wait to get the engine in it.It's definitely a hack job and looks like poop. But I don't think it would weaken it enough for it to be an issue. Either way, it's gunna be a sexy ass on this Baja ??
Yup. I remember you have the same setup on your hybrid. Question, how much lateral movement do you have on your layshaft when the case is closed up? I have about 2-3mm of play. Wondering if that's right?You did the write thing if you would have cut that piece out you wouldn’t stop thinking about it.
I had a good amount of movement with black one gears turtle racing case and kraken RC lay shaft. No movement when the whole ass end is 100% assembled thoughYup. I remember you have the same setup on your hybrid. Question, how much lateral movement do you have on your layshaft when the case is closed up? I have about 2-3mm of play. Wondering if that's right?
I wondered the same haven’t fitted the spur gear yet so I’m sure it will tight up a little more.I had a good amount of movement with black one gears turtle racing case and kraken RC lay shaft. No movement when the whole ass end is 100% assembled though
They are sloppy, but I say the 2wd fun makes up for it 10x. And I doubt yours is anywhere near as bad as mine is atm ??Cool. I'm new to the baja scene so making sure. Really not impressed with it compared to the Losi, to be honest. Everything seems a bit sloppy. But theres a loyal fan club for these machines, so we shall see? I shall march on.
+1?? once its all buttoned up y goldenI had a good amount of movement with black one gears turtle racing case and kraken RC lay shaft. No movement when the whole ass end is 100% assembled though
Well if you see how much mark had grind to get one to fit? not pretty??
4 imo?4 or 1 (4)
Those axles ? " Mr its so big" ?
Edit : fek off Doug , stoped editing my shite ??? I said "want ?" not "Mr it's so big " ??
