CustomCVP.com
- Dover, New Hampshire
Gents, we've got the protectors worked out for the DBXL, Stock and Extended, they will include the mounting hardware, and it's going to take some extra work to install, the pin setup that comes stock at the rear carrier is changed out to a bolt, the 5ive carrier bolt is perfect but buying the set to get the 2 rears isn't practical but I'll look into it because I can cut and thread the extra pins but ordering a batch of 5M bolts with threads just at the end may be better. There is also a pivot ball that goes between the protector and the arm at the sway bar location, this is a 3m bolt on the DBXL where its a 4m on the 5ive. This keeps the protector on the same plane as the shaft, there is a left and right also due to the way the rear diff is placed. As for the extended version, I had put as set of craftwerks 5ive extenders on my rig, then DGI came out with a full 1 inch extender, I put them on yesterday and redesigned the profile of the protector and put them on with the stock wheels and put them to the test yesterday, no issues with the protector but let me tell you those extenders are awesome, the truck is so much more stable, I'm running the OBR reed case in mine and it's over powered for sure, I beat the snot out of it and I couldn't get it to roll over, wot turns, doughnuts, I couldn't believe it, the CW extenders helped but I could still roll it, a couple of time while making hot laps around my track she looked like she was getting light on the inside wheels and may have lifted a bit but never went over, total blast to bash on. Again stock tires still not taped up, I will put the Mickey Thompsons on today and try again to see if a harder tire makes a difference. This post was to let you know I have the protectors for the DBXL but really I wanted to rave about the DGI entenders. worth every penny and if you power it up I don't really see how you can bash it hard without them. Every one's opinion of bashing is different also but when i'm testing my stuff I beat my poop to death, with the warmer temps I was able to tune the mill more for preformance, I run fat in the real cold and it's just plain sick, I'll get some video for you soon. I need to do some more research on the hardware to give you a firm price, they will be in the mid 30's and will carry the same life time warranty. If your interested in a set pm me here for now. I'll do a give away soon also. I did put the Bartalone braces on, they are nice but I don't think they had anything to do with the lack of roll overs, that's all the extended wheel base.... Awesome I'm new to the DGI parts and so far I'm impressed, the push rods are sweet too. Over and out.
How about some HD video to check things out.
[ame]http://youtu.be/DjQqRDXgZj8[/ame]
[ame]http://youtu.be/aVapUsp6984[/ame]
[ame]http://youtu.be/A0cFJi6IiKo[/ame]
[ame]http://youtu.be/Wwl5EUSS1b4[/ame]
