Martin_
Hi all, i need a little help here, I have a misterious problem with an engine, this is a CY 29CC billet head kit, 35mmBore/30mm stroke(stuffed crank), 14:1 dome, OBR reed kit with windowed piston, I cut 5th and 6th transfert port,
I widened the exhaust port at the maximum and increased to 190°.
That engine start to act weird somewhere after 4 tanks,(actually 8 to 9 tank on it) like if it's starve on fuel when I pull WOT and then let it back to idle, I tried everything, this is the 3rd time I took apart the engine, and everything seems visually fine, last time I opened it, I put new TFE bearing, new crank seal, sealed the head gasket, etc... there is absolutely no leak anywhere around the engine.
I tried 3 different carbs, I even put a modded carb with a lower pop of pressure..... nothing, it act exactly the same no matter what I do....... and no it's not the 90° elbow on the intake, I tried without and it changes nothing.
My guess is a crack somewhere on the head or crankcase, because when the engine is cold, it run alsmot normal in the first minutes, when it start to warm up, the problem increases, then at normal operating temp, I cannot run the engine for too long, It act very lean and I'm afraid of seizing the engine, and if I let it cool for 20 min, It runs fine again for a few minutes, then start to lean.
I don't know what to do more...........
Here are some videos , vid:1 cold engine, Vid:2 mid temp, Vid:3 operating temp.
Video talk by itself,
VID 1
VID 2
VID 3
VID 1
VID 2
VID 3
