46u
- Macon, Georgia
Who here is running a bolt on cylinder reed motor? I understand you have to have the proper cylinder with windowed piston and all. What are the disadvantages if any and advantages over a slandered engine? Does this type of engine have good low-end torque? Is there any particular displacement that runs better then another with this set up? Is the only thing you have to do to built it in a 5b is the throttle linkage? Do you need special pipes for this type engines? Please educate me and thanks for your input.
