DBXL-E questions
ultamotiv
New Member
Hello,
Recently got a dbxl-e for a project i'm working on and have a few questions i hope someone can help me with. A bit of background to give you an idea of what i need, the chassis is going to be fitted with an upper deck to mount things to and needs to be able to carry weight of up to 20kg. With this in mind...
What is the lowest size of pinion you can fit with the stock motor mount and spur gear? and where (preferably in the UK) would i be able to get one?
What the spring rate of the stock springs?
What would be considered weak spots in the chassis that would be wise to carry spares of?
Are there any kits available to install double anti roll bars and double shocks on both the front and rear? Or are there any manufactures providing anti roll bars that are significantly stronger?
Thanks in advance and any input is welcome.
