Awesome custom parts!
Looks like you are using the stock DBXL-E motor mount from LOSI. Was wondering if you had to make any modifications when fitting the 3080?
Any run videos of that beastly Vekta you built yet? Dbxl looks sweet.?
Did not have that problem. Your DBXL-E is V2? Anyways you can use a stepped drill?Greatly appreciate the quick reply sir! By the way, that's one impressive and expansive ESC!
The front bearing on my motor will not fit into the orifice in the motor mount. I suppose yours did not have this problem?
Is that a fixed motor mount with out motor adjustment for different size tooth pinions?
If not ,you might run into trouble when you need to change the pinions ,unless it runs to some other diff!...
Soo.... Your to blame for our current power outage?Sent out a massive EMP causing rolling blackouts in your area?????
Nah, that was Covid19's fault?Soo.... Your to blame for our current power outage?
