Bryan K.
- Richmond Hill, Ontario
I did a few runs over the weekend and had a fuel pressure issue with the priming bulb or diaphragm. Towards the end of the video, you can hear the loss of power as the engine barely revs and stays in that flat power curve. Eventually, the motor just stalls from lack of fuel pressure. Lots of bubbles in the fuel line and the fuel will fill about 1-2mm of the priming bulb. When priming I had the same issue, just barely got any fuel to stay in the bulb. So brought it home and swapped out the priming bulb and diaphragm base out of a spare 668 carb I had laying around. Primes just fine now and holds fuel at idle. I haven't tested it on a proper run yet, but seems to have fixed the issue. The odd thing is I put the old bulb and diaphragm back into my spare carb and tried to prime it and fuel filled up the bulb and pushed fuel through the lines with no air bubbles at all. What's the deal? I'm still learning about 2 stoke motors as I'm pretty new to them. I've fully rebuilt the internals of a few already (pistons, crank/rods, rings, bearings, etc) but I have yet to touch the carbs or really know how they work. All my lines and even the tank are brand new and I've tested them all for leaks. The cap is also brand new and vents properly.
So what am I looking at here? I understand that the bulbs crack or become brittle over time, but this doesn't seem to be the case here. What else should I be checking for? Why did this happen on one carb yet it works fine when swapped to another?
In the past I noticed the priming bulb on my Hpi Baja is like 90-95%% full when running yet my DBXL's priming bulb was always 50-60% full while running. Is this an issue and already a sign that something was wrong?
thanks,
thanks,
