Shoppingcart111
- Reaction score
- 4
New to the forums and need some help. DBXL 2.0 gas buggy. I run either JConcepts choppers or Proline Mashers. We race on a clay track and i found the choppers still didn't bite as good when dry so went to the mashers. Stock clutch spring and gearing. For diff fluids (All TLR wt fluids) I was running 100k c, 50K f and 30K r. Things seemed ok.
I had switched to a 19T pinon and 8K clutch spring(complete new clutch) for the mashers and then switched the diff fluids to 500k c, 100k f, and 50k r. after a race last weekend the first qual seemed good then the second qual it felt like the clutch was slipping but kept running and then before the race it didn't feel good, started the race but after the first lap it was apparent that something wasn't right and pulled out the race, went back to the pits and found the center diff leaking fluid and the rear seemed to be skipping.
Once at home and tore everything apart, the center diff was destroyed, basically it tried to spin the spider gears inside the housing, and the rear diff, it cracked the outer case so the ring and pinon were all stripped, and the front it looks like there's more ware on the ring/pinon. So long story short it was around 400 in repairs. New center diff housing(alloy) and gears, new front and rear ring/pinons and then some hop up parts in while its apart.
So after all that my question is what the magical mc f$%k happened? hahahaha. I'm thinking it was the thinker diff fluids that killed it, basically acted like a locker and that didn't like the race conditions. I read that lots of guys run 500k in the center with no problems.
Im thinking of going back to the stock clutch spring(lower so im not wringing out the motor) sticking with the 19t pinon and stock spur, and back to 100k C fluid and maybe the 50k/30k F/R for the diff fluids.
What's everyone's opinions? Sorry for the long rant but i cant have this kind of damage again as i cant keep dumping money into it for repairs. Mods is a different story.
