Digital or analog?
There is nothing on them to indicate what they are. I'd say analog because they are very cheap for the size of the servo. The digital servo are usually more money than an analog even if it is a good analog servo.
ok cool. I need to know that cause on my futaba remote I have to set it for the correct servo. If I have it set for digital and the servos are analog,they would burn out
REVOlutionary Rampage said:
I would almost replace them before you run. the servo's in mine didn't last long. Most people upgrade them anyway.
All 3 of them? What good digital steering servo you recommend? I am going to put an align d's 10 for the throttle/brake
Futaba and Hitec are good brands to look at. You want your servo's to be quick on the throttle, if its a throttle servo. But able to push the tires back and forth easily, if it is a steering servo. I have 2x HS805BB, which aren't speed demons but work well. 300+ torque is what you are looking for.
Do a search of the forum. What would work for me might not work for you. Ask someone at your local hobby shop what they use or would be a good servo.etc..
