Do I need to retune after changing to k&n cone filter?
Yea run it a bit, but I don't think it'll change it much if any....
Gotta rebuild my pull start today, hopefully be good to go for Wed... :)
Mine is running after tightening the air and carb bolts. Also got the 5b running I think the plug was bad. Changed it out, retuned and it's running. Running so well I flipped it like 4 times and broke the steering bell crank. Oh well. Slash is perfect after the beating it was given
Did you break the KM or the Ramp?...doesn't matter, just try not to break the other one by Wed...lol...I may not have the Flux for the same reason (steering bar broken)
K&N cone filter
boriqua935 said:
Put one on with a prefilter. Do I need to retune?
Hey boriqua,
where did you get the k&n cone filter from, I need to order on, I have a 26cc motor but I want it to go faster, do you know of faster motor that will fit right in, one that I can get a better bang for my buck!!!!!!!! I see your in norther Jersey what part, im in Orange, mybe we can hook up and run the trucks
Go to ddm I got item nber af225 'ufo' carbon filter kit. It's $15. You will also need a velocity stack to mount the filter. I have the af200 stack. If you have a choke on your carb, you will have to open up the hole on the stack a little. I just used a dremel to grind it open a bit more. No big thing
98cruiser there are a few guys on here from jersey. We met yesterday to ride. Pm me. Krashkrieg, igetbombed and trickle007 are also from jersey
