Hi...before starting I kept the choke on to start the engine...once it get started when I put the choke to off, the engine also goes off.bear with me on this , i'm not trying to be funny or anything mate,
but, are you sure you're not starting the engine with choke off, then putting the choke on when its started ?
easy mistake if you are, all the rc engines i've had no matter what make they will not run with the choke on, you only get a pop, then choke off and pull till it starts,
I am running it with petrol and oil mix. 1:25 ratio ..if it is an air leak then how to fix it .Could be a fuel issue or an air leak
Fuel starvation problem or air leak. Pressure vac test is the proper way to test for air leaks. But a can of carb cleaner will be just as effective. Fuel issues are fuel line, dirt, or carb related issues. As you say it's new, which means it's a rovan or king motors. I suggest you go through them for warranty purposes.Hi...before starting I kept the choke on to start the engine...once it get started when I put the choke to off, the engine also goes off.
Fyi...my Baja is a brand new one...
You’ve not answered Spents question. Are you sure you’ve got the choke in the right position? Take the air filter off and take a picture of the air inlet and tell us if you have the choke on or off?Hi...before starting I kept the choke on to start the engine...once it get started when I put the choke to off, the engine also goes off.
