Does Anyone Know...
Kwakr
Thornhill
I have an Fg tuned exhaust (chrome), and was wondering if anyone knows if a silicone nitro exhaust coupler would withstand the heat from our engines??
Or any alternative methods of "coupling" the header to the exhaust???
cyclops1970
Hamilton Ontario Canada
i found the best coupler is from Aviation or plane exhaust couplers .. buy the thick ones .. i bought the thinner ones and they tore ..
thats about the best advice i can give ya . worth the 5 bucks ..
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
Ok, tested and somewhat proven. It works great but still dry cracks the inside alittle after some long time usage but, easy to put on and off for replacement.
It is available at the auto store made for the catalytic converter and is a 100% silicone type tubing and yes somewhat pricey but it is sold by the inch or foot so not so bad. Here is a photo of my 3pcs FG on the FH.
SELWA
Milton,On CANADA
Yes the aviation type works good. You will find it in "blue" at most LHS that carry planes. I still use this on my Samba to give it a tighter seal as well.
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
Hey BtB, looks like you have a plastic servo tray. Does it flex when you brake ?
Yup, not as much as my MT with front brakes which flexes like mad! Need the upgrade soon for the MT then the firehammer in the future. It's working for both but, I could get better response and torque if it were alloy.:(
Chop Suey
Ontario, Canada
OR just a cheap, quick do-it-yourself fix... add 2 more posts on both sides of the tray at the front. Cut a couple of plastic rods about 8mm, drill a couple of starter holes in both ends for M4 screws, drill 2 countersink holes on the chassis, drill 2 clearance holes for M4 on the tray...voila... You'll be surprised how much improvement that would make because with the current set up of only 1 support connection in the front for the tray.
Just a thought.
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
Just a thought.
Good idea.:)
leadfoot
Adelanto ca
jetpro pipe
hey BTB I got my jetpro pipe installed but the only problem is that it leaks and yes I did put the gasket in it dosen't leak that bad just leaves that black stuffon the gas tank? what do you think:oops:
prefa1
blue mountains
silicone can withstand great heat,it is used on industrial and commercial machinery....you shouldnt have too much trouble....
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
Did you reuse the old gasket or use the new one that came with it? They are rather cheap to replace. I went through a few before using a torque wrench when fitting the pipes, ya I know, way over board but I was terrified to strip out the head!:blush:
Surprisingly I found I was not cranking them down enough to seat tightly.
Use the figures found here for exhaust bolts - https://www.largescaleforums.com/forum/showpost.php?p=9272&postcount=2
You may be able to tighten it and work but, usually once they start leaking the gasket fails - Most of the time but not all the time...:)
Kwakr
Thornhill
WEll..i did get around to get a slicone exhaust gasket used on planes engines..rc kind..not real;)-as Joe was suggested....but just been sooooo damn busy with work...that the g.f screams if i go out and play too much!! More play=less time with her...and i haven't figured out whcih is the bigger investement yet..her or my truck!!! Hehe...probably her!! BUt shhhhh...
I did get to run it a few times and it seems to be holding up fine!!
leadfoot
Adelanto ca
jet pro
hey BTB again you have been a big help I am like you I terrifed too strip the head But that would give me a good excause too go too a biger motor like a 30cc but your right I plan to buy a new gasket and convert it wiht the right torque and then will see hey do you knowif I go too a biger motor can I use the same pipe I have all the time too do it right I just had back surgery I get too play for a while:devil2:
Timmahh
Bajastafarian Madnes
PLUS member
Michigan
ddm 59.00 Zen 260 top ends on sale atm
115. gets the race ported G290 top end ( 28.5 cc on the stock 28mm crank, 30.5cc on a 2mm stroked crank)
BUY BUY BUY> lol
Trip
Ypsilanti Michigan U.S.
Does the race porting make much of a difference over stock 28.5 porting? Wondering because I don't want anyone to know what I have done...:ph34r: I have another 28.5 head kit ready to be put in another truck.
Thanks,
Trip..
Timmahh
PLUS member
Michigan
not having run a 28.5 stock i cant for sure say, but i will say the it deffinaly has a good fast spool up and is damn controllable ( elecs used make a diff here ). i m 95% sure the stocker would have some off the line bog, and be slower to spool and less responsive.
i would say its well worth the cost of admission from 85 to 115 for the port work for it! i love mine. Great Torque with the 36mm piston/bore ( no replacement for displacement and all that ) and being 28mm stock stroke, i have killer rpms imo.
but its important to note, the port work done, needs to be done properly or you ll have poor or even less the stock performance results.
ESP does some Killer work. and hes a Michigander to, so thats a bonus.
DDMs other builder also does nice work imo ( current topend i have ).
Not owning/useing/seeing an OBros motor perform except on line, shows their work is also good.
but for the most part, i recommend Doug at ESP. his work is top notch and hes a very smart cookie, and a Hella Nice indvidual as well as a Michigander. lol
leadfoot
Adelanto ca
heads
what head do you all recommend for the stock 23..cc motorand what size is the stock crank I am going too look in too this.besides the pipe is the head a good hop up for the money or should I wait and save the money and buy the 29.cc motor
