does the cup in the upgrade kit have the same problem ?mooman007uk said:seen this a few times...BC Bob's has done a couple and an outdrive cup. Did you temper the shaft? If you did you might have put too much heat at the cup and softened it...if not tempered then you got a soft one from the factory.
I've not had one go like that in a year
My Ramtechs are starting to get notched also. Rob might have heat treated the entire cup instead of just the shaft. The shafts are holding up well though.rob64n said:sorry to say this but the tempered ones i got from rob are doin the same thing but the stock ones are not
Holy crap!. That thing is as worn out as a 2 dolla crack whore. What car did that come off of Rudi?Rudihenriksen said:It is not worn.
But THIS is worn![]()
Were did you get the boots?kirkhayes37 said:Get HPI Baja 5b or 5T drive cup boots fill them with grease and they will last a loooong time. I have boots with grease in them on both ends of each dog bone on all four corners of my Rampage MT. Makes it run quieter with less worries about wear!
HPI baja from Turtle Racing.catchaser said:Holy crap!. That thing is as worn out as a 2 dolla crack whore. What car did that come off of Rudi?
There is light at the end of the tunnelmooman007uk said:I was running dark soul boots on all my bones, shredded everyone of them...waste of time for me
How did they rip?By rocks and stuff hitting it? or they just rip by them selves as they were moving?mooman007uk said:I was running dark soul boots on all my bones, shredded everyone of them...waste of time for me
I will use mine and if they rip quick it will open dog bone too for memooman007uk said:mine ripped just with general usage...i run open bones now with no problems
