I have 6 V stock battery.The other servo is...stock. Can be any problems if I use LiPo ? I read on other forum..."do not use LiPo" battery on DBXL.Tks.in order to see the full potential from the Savox servos (0235, 0236, 0240, 0241), you'll need to obtain a 7.4 LiPo battery to replace the stock 6V battery. When selecting the a battery, be sure the size is correct for the battery box and the connectors are the same. Another solution is to get a larger batter box and battery:
http://www.killerrc.com/product/losi-dbxl-box-lid-kit/
Do you use regulator ?I use 7.4 in my stock DBXL and it was fine yes is not rated for it but it does work
Do you use regulator ?Same here. 7.4v lipo. No issues.
