- Crafers South Australia
- Thread starter
- #161
Yes it does heres mine???Modified RC rear plate goes nicely with the Scorpion frame
Yes it does heres mine???View attachment 55062
It's ok jim.....? not gonna come out and say its perfect. I'm gonna have just run a drill bit through the tank hole mounts co the little plastic posts are just not fitting ? but don't think it's a big issue?? the Finnish is great??nice!
this is going to be epic!
what do you think to the fit and finish of the chassis doug?
Nice Doug!! How'd you get such an awesome finish on that tr plate?
Damn no polishing or anything huh, looks great ?Came out ok eh?? used caustic soda 2 tablespoon and kettle (hot) water just enough water to cover the plate. Was only in for 1 min max ?? color jus ran off?
make y self a nice slot with y foredom on the top off the radio box nice n clean.Playing with the radio tray?? mounted my savox servos and full force braces ?? will have to move or make some plan with the on/off switch.........suggestions??
View attachment 55066View attachment 55067
I had the same issue with the radio box pegs on the rov when I installed my scorpion. thought it was cuz it was a rov but no oddIt's ok jim.....? not gonna come out and say its perfect. I'm gonna have just run a drill bit through the tank hole mounts co the little plastic posts are just not fitting ? but don't think it's a big issue?? the Finnish is great??View attachment 55063View attachment 55064View attachment 55065
Mounted the tr steering thingy and irp turnbuckles??
i reckon the holes are drilled then chassis gets bent ......holes change shape after the bendmake y self a nice slot with y foredom on the top off the radio box nice n clean.
idk I drilled mine out loli reckon the holes are drilled then chassis gets bet ......holes change shape after the bend
I had to drill some of the holes out in my scorpion to on my last build. Fairly common with them
guess u like my parts wall thenlove the looks of everyone's 5t/b builds.
You know it. If I didn't already have the Rovan, I would've been got one of these.guess u like my parts wall then
Well I guess you'll have to get one??? coz this ain't no rovan ??????You know it. If I didn't already have the Rovan, I would've been got one of these.
