buzzkill
Mad?scientist
- SLO California
I was going over a Dynomometer in my head and looking at designs , I think I can put together a low cost fairly accurate one for maybe $200 or so ? . Make a disk brake type unit with a load cell and sparkplug wire RPM sensor this would measure either at the large spur gear ( motor power ) or the rear hub ( drive train power ).
parts 1. Carbon fiber disk brake setup https://www.kingmotorrc.com/product-km66002s 2. load cell 3, Arduino for measuring the load cell and rpm's 4. a axle that connects the Hum/Spur gear to the disk brakes 5. pillow bearings to run thru the axle 6, and arm the holds the calipers and has a 1ft extension ( =1 ft/pound of load on the load cell ) and a large plate to mount it all.
for the hub style you would strap down one wheel to stop it, for the spur type no need ,but you need to strap the car down also !
what do you think ? could be shippable to try it out also ( in USA)
Quote Reply
Report Edit
Losi DBXL G320
Many others....you know..
Like Quote Reply
Report
Reactions: Cooper04
Also the correction factor is so we all speak the same hp numbers no matter elevation, temp, humidity or what have you. So dyno at 10k ?
Losi DBXL G320
Like Quote Reply
Report
Actually you could adjust in math for the gear ration very easily when you download the data just add it to the equation.
Quote Reply
Report Edit
Reactions: Seandonato73
Quote Reply
Report Edit
Quote Reply
Report Edit
I copied this over from another thread , If the mods want to move it over thats fine , I just didnt want to over take the other thread
Quote Reply
Report Edit
Seandonato73
You would still need to know barometric pressure, humidity, and a few other inputs for correction factors. But yeah for an extreme low budget build that sounds promising.Losi DBXL G320
Like Quote Reply
Report
Reactions: Cooper04
you could manually account for that stuff , I mean if your at 10,000 ft don't dyno a motor LOL ! , I have a control/readout system already 95% built from my Composites press with a 7" touch screen I just need to change the Temp. input to a RPM input , it also has data logging built in also ! see www.masterpresses.com , that would be the interface and it could be programmable .Seandonato73 said:
any idea what the differential gear ration is on most cars ? 1:1Seandonato73 said:
Seandonato73
No I unfortunately don't, I didnt run a wheel dyno, just an engine dyno. So the ratios wernt an issue. I know you pull in 4 the (direct gear) and then theres the rear end ratio and tire size that play a factor. But beyond that never messed with it much. I would think it would be a lot simpler when just using a fixed gear ratio to keep a pump within its rpm range.buzzkill said:
Losi DBXL G320
Like Quote Reply
Report
buzzkill
my plan was to attach a disk directly to the hub HEX ( if they are the same size ? ) but ya gear ration will effect rpm's , direct to the crank would be better , I need to look at that closer ( more cost IMO).Seandonato73 said:
Quote Reply
Report Edit
Seandonato73
Direct drive with a love joy and keep the clutch set up, would make starting easy, amd have the ability to swap out to a different size clutch set up at will. And no gearing. I keep forgetting you said about a brake set up, I keep thinking about the hydraulic set up I have plans for.
Yeah you could adjust, I'm sure theres a chart or something for the correction factor.
Losi DBXL G320
Like Quote Reply
Report
I can measure mine , just spin the large spur gear 1 turn and measure the turns on the HUB , WHAT is a LOVE JOY ?Seandonato73 said:
Quote Reply
Report Edit
buzzkill
Ok the final drive on my ROvan 320 is 2.5:1 and I have a 16/58 gear set the gear set is 3.625 x 2.5 = 9.0625 final drive ratio so at 10,000 rpm the tires spin 1103 x'sbuzzkill said:
Quote Reply
Report Edit
