corn juice
Reading the Rules!
if you read the thread on doing your steering setup right , this is right up there with it. Take out your RX box and lock up the rack with bolt trick so it is true center. unclip your front roll cage pins,raise cage front. now take a framing square and put it on the top of tub and slide it to ears on top plate and the slide it so other end makes contact with rim/tire. the plate ears should be square as it is screwed to bulkhead. with the rack in true center and using square you can VERY EASY get the perfect front end that is centered with rack swing. side to side wheel adjustment is a flip of framing square. simple.....fool proof.
