engine oil
foxy
staffordshire
:rolleyes: wot oil do you men run in your engines ? no one round here sells the king cobra oil only [EBAY][/EBAY] postage is expencive :lol:
Pretty much any synthetic racing two stroke oil you find at your local motorcycle shop should be fine. Just be shure to keep the ratio at 25to1, or what ever is reccomended by the maker of your engine.
Do a search for it foxy. There have been a few threads same as this. Everyone uses different oil usually whatever is readily available near them.
I simply walked into Halfords and asked for the best synthetic oil they had, which was Castrol at the time.
So far, no problems.
I don't use mine nearly as much as many of the guys here, but I run at 32:1. I always ensure the exhausts a bit smokey - indicating oil is passing through ... the only way these engines get lubricated.
Im similar to you mate. More occasional use than most and a smokey exhaust :D I use 25:1 tho on King Cobra gold.
Here's a similar thread foxy.......
https://www.largescaleforums.com/showthread.php?t=4051
