Engine wont rev an doesn't accelerate
Nolimit
Likes
0
Maryland
Thread starter #1
Ok don't no whats going on here just upgraded servos on t1000 everything works steering an throttle/brake. Now when i start the car it wont accelerate nor will engine rev up. Everything worked fine until i did the upgrade
Nolimit
Likes
0
Maryland
Thread starter #2
Linkage seems to be fine plus the arm on the carb moves all the way up but engine doesn't rev
atom3624
Likes
105
Cold, wet, windy St Helens, U.K.
#5
OK, daft question!
The LINKAGE to the carb moves, but is the SHAFT actually rotating in the carb - has the screw loosened and it no longer turns the shaft?
Nolimit
Likes
0
Maryland
Thread starter #6
Nope everything moves an the brakes work fine to. Tried swapping a diff carb an threw in old servo an still same outcome
