Back when I used to ride dirt bikes(I was 12 years old or so) we never did try that freezing technique as our freezer was never large enough to hold something that large. Also I doubt any mom out there would ever let a crusty exhaust into the freezer just to fix a dent. The fix back in the day was to insert a rubber expansion plug on one side. My dad fabbed up a t-fitting with a rubber coupler;
-1 side would have the rubber coupler on to the sleeve(other end of sleeve would be on pipe) while both ends secured with hose clamps.
-1 end ended up with some sort of tire valve stem.
-last end just had a pipe plug installed.
With an acetylene torch we would heat the dented area cherry red hot. Once hot enough, grabbed a tire inflator/air chuck, hook it up to the tire valve stem and fill with air. The air pressure in the pipe would push out the dented/cherry red hot area out. Keep in mind it doesn't take much pressure to pop it out. Once satisfied, remove the air chuck and remove the pipe plug quickly to relieve the pressure. Also keep in mind it never ends up looking like new, small blemishes still could be seen. Once the area is nice and cool, sand the area and/or the whole pipe assembly and repaint with some high heat stuff.
this is the best method and does work well as you're only targeting the dented area..you can plug one end with a compressible bung and use a rubber end on an air nozzle (check pic) so the pressure is released instantly as soon as you pull the nozzle away, the freezing method doesn't target just the dent so can split the pipe especially a thin wall pipe like the VRC or samba.
No doubt will roll it again....and again and again, maybe youre right lol, is it worth trying to get it out only to gat another the next day,anyway, its ready tommorrow, will get it back and have to run in new top end....going to be so hard not to blast it to see if it wheelies. I understand ther are people that rag it from the word go,,,we will have to wait and see!:lol:I would leave the dents in it personally! Next time out, roll over, dented again - doh!!!
lol are you kidding? milk? did u put 2 sugars and a tea bag in it ,lol the dent is near the end of the can above the support brackrt(jetpro 2) not on a straight bit,curves around to end pipe.size of a 10 pence piece
