Exhaust recommendations for Losi 5t 2.0?
Thread starter #1
bigdipperfred
Likes
121
somerset nj
Any thoughts . and recommendations for exhaust.Zenoah 32 cc engine for all a round use.
Whoduh
Likes
404
Fairfax, VA
Whoduh
Likes
404
Fairfax, VA
This is the location of the bolt that was giving me problems. The MIP kit(thank you dougstar) is installed in the pic though.
The angle of the header makes it difficult to get a stock bolt tight. It would always back out
Ball ends wouldn't really get in there either....exhaust kept spitting all over the crankcase and rear brakes. The MIP kit (thanks dougstar) solved that issue. Twisted wire keeps the bolt from backing out.
dougstar
Likes
1,842
KZN South Africa
your mod looks very different to the one offered on DDM? get how a wire through a cap screw would work but not on yours please enlighten me
Whoduh
Likes
404
Fairfax, VA
:unsure::oops::banghead:You know what.....you are 1000% correct. Its the MIP kit i have on there. I had the bart kit on the DBXL w/Jetpro pipe. The Bart kit
http://www.davesmotors.com/Bartolone-Racing-Pipe-Wire-Kit.html
did NOT work with the angle of the Victory header....same issue as if you were to use stock bolts....i tried the bart kit first(cause it held the jetpro on the DBXL).
** I edited the original post with the correct info.**
I tried the Stage 8 kit next.
Didnt work for me with the either with theVictory header. The spacers put the bolt head really far out and i could never get the those stoppers in a position where they would actually do their job...plus the spacer deformed a litte cause i over tightened it...threw one out...which is why there is only one in the pic
MIP kit works. Regular small wrench to tighten...thread the head and twist the wire. Not possible for it to back out.
Sorry about the wrong info earlier.
evssv
Likes
1,481
Bristol uk
I ran a samba on my 34obr..it was good...(y)..but now i run a bart xp big bore and it made a world of difference...:cool:
Mike44
LSF Plus Member
PLUS member
Likes
34
Kansas City Missouri
Im pretty new to this game and all I know so far is what I read, I was under the impression that Bartolini was a pretty good exhaust system but none of you guys mention it. Whats the deal ? I was seriously thinking of getting a Bartolini when I got my 5t , should I be looking at other systems?
Likes
37
I have a olimat pipe sitting on my dineing room table just waiting to be plated and for the 5t2.0 to get here.
Just found out the Olimat pipe for the 5T will not work with the 2.0 version.
Spoke with Simon from Olimat and of course he made it right; 100% stand up guy.
