exhaust repair(jb weld)
ive got some wrap but if I use it have to be
a permanent wrap with jb weldsf ever wanna change
exhaust I will have to cut of,
thats why I haven't used this time, so can just about get
nut on thread
ahhhhhhh new fiddlesticking top end is needed lol
hi guys
welding is not an option,
will jb weld hold work on this hole ?
and should I use it inside or out ?
its properly 1mm wide by about 10 long very thinView attachment 46604View attachment 46605
JB Weld will not hold. I had a similar problem with the exhaust of my Redcat-Racing Rampage XR. The heat generated from the engine simply melted the JB Weld patch. In the end I had to buy a new exhaust system.
the exhaust at moment is a headache , ive got victory
side pipe but issue with that when I buy sandrail cage
the pipe won't fit inside it
I knew the jb weld was going to be an issue, u would
think it would hold as its within the heat parameters
