Thanks, so will the DDM dominator for the MT work on mine? Don't care much for the jetpro looks.Jetpro side or rear or DDM dominator. CPI is out of business it seems.
OK thanks, don't want to cut up my roll cage. Any problems with side exhaust with oil on the tires?The DDM is not a direct plug and play. To fit it requires modifications to the roll cage and mounting points (see pics below mounted on a MT). Some didn't care and made it happened. Your sure plug and play option is the jetpro.
I see you have the MT, I have an XT so a little bit different.View attachment 13494 When I installed my ddm dominator I didn't have to do anything to the roll cage. I did rotate the fuel tank 180 degrees, for easier access to the fuel cap. I still need to trim the body a little bit where the pipe comes out.
