Extending Air Intake Manifold
T3X
Is there a product out there that can make this happen. I want to extend my intake to bring it up to the front so it can actually look like a real intake from under the hoob. Something like a manifold extender of somewat??
Thats still a bit short. Was looking for something a bit longer.
Tyvm
Are you wanting an extended Intake Manifold, or just a longer Cool Air Intake? The longer the manifold, the more vacuum is required to 'pull' the fuel/air into the cylinder so unless you'r running a higher compression engine, I would highly not recommend it.
If you simply want your cone air cleaner to stick out, then that's as easy as making your own cool air intake using any smooth piping/tubing.
Forgot to mention, running an extended Intake Manifold will also kill your low end torque, again, because it takes more 'pull' to get the fuel/air into the cylinder because the carb. is further away so there goes your hole shots lol.
how bout this , PVC 1 1/2" 45 DEGREE , heat it up a bit and slip onto stock air intake. clip off stock elements in the way. SEAL IT ! with silicone and a small tap screw.
I didnt want to move the carb. I just wanna move the filter up more to the front. Phreerider idea is preety good too. Any other options?
Phreerider's route is the best. You're not going to get better. Obviously you can route the PVC to suite your liking. Have seen guys for years build cool air intakes from PVC for large CI bikes. It's cheap, cuts easily, smooth surface (more tubing joints = turbulance). I think what you have in mind is called a 'velocity stack'
well i guess ill look into it and see what i come up with. if i do find anything or make anything ill be sure to post some pics. thanks for the input guys.
