Fg baja 2wd manual?!
Also, I don't have time to print that tonight, do you know what size screws go to the bottom of the motor?? One came out and I lost it, I think because of the movement of the motor now it's causing the gears to grind together.
Np buddy...... Yikes that's not what I want to hear right now. Been putting off buying the alloy motor mounts. I will measure mine now. You should def pick up a digital caliper, worth it's weight in oil! Lol
If we're talking one of the 4 screws that hold motor they are- 15.5mm long and 3.05 wide.
Can't help ya on the threading. I would def take the others out and take a ride to HD so you get the right one.
