FG Ferrari F360 Bumper/Foam.
Running 5 to 8mm of toe out wouldn't make the tyre wear worse but it would give you a ton of stability.
p.s the tyres aren't expensive if you know where to get them ;)
Back to the Original Topic ..... !!
As mentioned above, I've finally located the FG F360 bumper and have purchased the 8418 generic bumper / foam, with the 8120/01 Calibra bumper - as used by the FG F360 and the FG7011 lower front mounts.
I could never figure out the 'fairly unique' decals nor the mount hole in the middle.
I did a little more searching, and found out the DeAgostini did a 1/5 Challenge Ferrari F360, with precisely the same stickers.
The body is DeAgostini, not FG, unless DeAgostini continued using the FG bodies .... ?
The moulding appears as crisp as the FG, 'though I may be wrong?
I only see one moulding, not multiple pieces as FG do to permit breakage replacement and most probably crisper moulding.
I'll have to wait and see.
For all who knew, possibly not, I finally figured out that my 'unique looking' F360 was part of a series run for of a Carson chassis with an F360 body, known as the Challenge Ferrari.
There are still actually new, unpainted bodies still appearing on the internet, and also silver coloured wheels with 'Ferrari centres'.
I am intrigued, and it will be much more for 'show' rather than 'go', so I'm not too bothered about tyre selection.
Another 4 days and I'll see what I bought!!
I'm back on a 'plane to Blighty' tomorrow!!!!!
Finally !!!
It does look very straight, or slightly toe-in.
I reckon I've 'found' my 'new' F360.
Look at my purchase, including centre mount hole - so much for not wanting any drill holes!! and raised Ferrari sticker at the front - above missing corsa sticker .... who cares. It looks good and for that price, it wasn't bad.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?VISuperSize&item=180742431421
http://www.youtube.com/watch?v=AnuM2A15UGE&feature=related
A couple of stickers are missing, and the windows are blacked out, for a reason I'll find out when I get back to UK .....
Unless this was a standard sticker set, and mine is one of many .....
Anyone know which model had the centre front body mount?
Great detail, be nice if the body was 20mm or so wider that way the wheels would be inside the fenders for a nicer scale look
