Splitpin2005
- Norwich
I have had this problem onece before. I pull and pull, flood the engine and the truck wont go. Last time this happened i almost gave up after days of trying, but then suddenly it fired at away it went.
Well now the problem is back. I have checked for a spark and yes there is one. Its definately getting fuel as i keep flooding it, filling the exhaust with unburnt petrol. And compression seems ok when i hold my finger over the spark plug hole.
I have tried cleaning out the carb completely, but still no luck. Have set needles to around 1.5 turns out each. Tried settings from earlier posts also.
Would to much grass insiide the fan cowel make any difference to the ignition. As i say i am getting a spark.
The truck was working fine, until one day it started spluttering. I had this before and found it to be a split fuel return hose. I again found a split in this pipe and replaced it. But still no good, truck wont start at all.!
Please help me, i just wanna play!!!!!!!!!!!!!:helpsmilie::helpsmilie:
