fg mt question on wheelies? help!
I was told a ddm pipe would 100% make a fg mt wheelie,interested to see the response to this thread. Have you changed the gear ratio on the truck by chance?
When you take off are your rear tires breaking loose and spinning or does it seam to dog on take off? Which DOM did you get? What are your carb settings at?
it dogs a little on takeoff but not really and the carb settings are about at factory settings and the tires don't really spinout unless im doing a sharp turn.
You could try the reverse the clutch trick to get a sharper bite on takeoff...What DOM pipe did you get, the bottom or top end?
Stupid question, but are your tires glued to the rims? I have a Jet-Pro silenced version 1 and Jet-Pro told me to richen the carb 1/4 on the high speed needle and 1/8 on the low speed needle. They also said if the truck won't wheelie, the carb is running too lean.
My truck flips over backward down every time I give it more than 1/2 throttle at takeoff.
If you have any kind of a stumble, you carb is too lean.
Trip..
