FID Racing Dragon Hammer V2
FID Racing DH
Reading the Rules!
shen zhen City ,China
Specification:
L*W*H:950mmX540mmX355mm
Length:931.6mm
Wheelbase:616.5mm
Front tire track:457.4mm
Rear tire track:461.4mm
Max speed:75km/h
Big chassis: 5mm 6061-T6
7mm Thick Shock Shafts
235mm Long CNC Alloy Bodied Rear shock Absorbers(225mm Hole to Hole)
185.5mm Long CNC Alloy Bodied Front shock Absorbers (175mm Hole to Hole)
61 Tooth Steel Main Spur Gear
20 Tooth Steel Pinion Gear
Fuel tank capacity:750ml
Body shell: CLEAR, With 2 Full Livery Sticker Sheets
Alloy front/middle/rear differential gear box
Off-Road tyres:179x75mm
More than half parts are alloy parts
RTR Net weight:18.5kg Gross weight:24kg
Engine Radio Gear and battery are not included
Carton size:101*60*41CM
Included in the Build:
Billet Alloy Front Shock Tower
Billet Alloy Rear Shock Towers
Billet Alloy Front Swaybar Brace
Billet Alloy Front Bumper Mount
Billet Alloy Front Top Plate
Billet Alloy Front Diff housing
Billet Alloy FULL Centre Rear Axle Diff Housing
Billet Alloy Front Chassis Brace
Billet Alloy Full Steering Set Up
Billet Alloy Center Bearing Holder
Billet Alloy Full Center Diff Tower & Brake Calipers
Billet Alloy Pinion Holder/Engine Mount
Billet Alloy Small Engine Brace
Billet Alloy Rear Swaybar Arms
Billet Alloy Shock Caps All Round
Billet Alloy Trailing Arms (Polished Silver)
Billet Alloy Upper Four Link Ends With Rose Joints
Billet Alloy Fourlink chassis mounts
Billet Alloy Fuel Cap & Filler Neck
Billet Alloy Extended Wheel Hexes & Caps
Billet Alloy Radio Tray Plate
Billet Alloy Rear Top Plate
7075 Turnbuckles
Item's Also Included With the Roller:
CNC Alloy Small Engine Mount
CNC Alloy Adjustable Throttle & Brake Linkage Set Up (Including servo Horn 15 Tooth Splines)
CNC Alloy Adjustable Steering Horn, With 'Push Pull' Linkages (15 Tooth Spline)
CNC Alloy Pinion/Clutch Housing To Engine Spacers & Chassis Mount
CNC Alloy Engine Spacer Chassis Plates
Alloy Servo Screw Spacers & Screws
FULL Air Filter Unit (Including Housing, Filter, Top Plate)
Fuel Line 'Anti Pinch' Springs
Bolts for Small Engine Mount
Screws For the Engine to Chassis
Bolts for the Pinion/Clutch Housing
Bolts for the Air-Filter
Gasket for the Air-filter
2 Full Sheets of Livery Stickers
Battery Tray Dimensions:
150mm Long 32mm Wide
40mm Deep, (45mm with the Lid on)
What is the reason for going with a plastic back axle when so there is so much alloy on the vehicle? It looks fantastic I might add.
perfect i do have few more more questions what is the gear ratio coming from the center diff/transmission?
and can you please post some close up pics of the the center diff/transmission
can you give me your email adddress ,i will send picture to you
dragon hammer V2(Gas car) gear ratio:20th:61th
dragon hamemr voltz(electric ) gear ratio :21th:57th
I bought the V2 roller from rcmodelz.co.uk, the price was £850 which i think is phenominal. Especially when you consider that you have to spend nothing more to get the vehicle you want. Unlike baja or losi which frankly you may as well build from the ground up. I am no expert at all but i find it fantastically strong for bashing and compared to my two bajas it handles a track brilliantly, i use mine at the MMR Raceway in Wiltshire. My only complaint is mine came with blown seals on the petrol tank and the front diff seals shrankin transit and all the fluid leaked into the box. rcmodelz however sorted both for me. I havesince had the same thing happen with the rear diff but overall its a brilliant all rounder. I managed to fenagel an OBR 340 reed intomine having only to mod the bracket slightly due to the lumpy billet crank case and my fears that it would be sluggish due to all the ally were unfounded as it goes like stink.
welcome dude (y)...i watched a dh at mmr track a while bak and it didnt like corners much.... :poop:.....but not sure if it was a v2........they look nice but i like to make my rc's my own by adding upgerades as n were needed .(y).....not sure I'd b happy buying sumin and not doing antything to it....but each to.thete own I guess (y)
Uhhh nice looking rig! Good job with that car! Would like to hear more abut this car. Any one have one? Happy with it?
Btw what would this cost to send to norway?
I also like vids;) But wow what a good looking car! Looks like good quality also
My obsession is now growing stronger!
If you go watch the other videos about the truck it's prone to rolling over in turns. Think the guy that owns the truck in this vid put axle extender on it to make it a bit more stable . He's got a few of videos out there.
