Revolauncher
- Endicott, NY
I purchased this to replace my worn stock CY pull start with alloy starting pawl. I wear out 2 of these a season on average and usually 1 flywheel starter cup where it intersects. Fed up with this, I was about to drop the $120 required on a Turtle Racing V2 pull start when I came across this blatant copy by FID racing. Differences look to be the coil spool is plastic not metal like on the turtle, also the rope is a rope, not a cable like on the turtle. I have never snapped a rope, but had a knot fail once or twice on a stock pull start. Cables, I had trouble with both wearing out bushing guides and spools in stock and upgraded pull starts, so now you see my history of frustration that led me to this $93 purchase.
The unit is well machined and fit is snug. The included bolts are mandatory as they fit the unit flush with the correct lengths. I blue thread-locked all of them and torqued them properly. My aftermarket alloy rear chassis brace on the 5ive T platform required trimming 1/8 in. off to give the pull start adequate clearance during install and removal w/o removing the engine. (a big time saver). My pipe was also extremely close so I raised the pipe support bracket 1/4 in. with an extra flange nut I had laying around and now all is well. ( The turtle is the same dimensions, so these mods. would have all been necessary for that part in my model as well) I only tell you all this because they are chunkier than the stock plastic units, no biggy.
Part is installed, works beautifully and looks trick. This requires much less effort upon engagement, and the handle is quite comfortable, even with stiff compression. I have probably 20 start and run cycles through it thus far, and it still feels like new operationally. I foresee it holding up several seasons before requiring a dog cage replacement ($19 part) compatible with turtle racing's own part #.
Summary:
+ fit and finish
+ comfort and ease of use
+ replacement parts available as the unit is serviceable
- Better part of $100 is meh' for a pull start
- Turtle racing unit is only a $20 more...
- chunkier and heavier than the plastic stocker....
Summary:
+ fit and finish
