Squizzy Ralph
Thats an awsome paint job you must be thrilledI was able to finish building my 5B and even gave a go at the paint.
Very true i was not happy about this step but it has to be done were the body gose up for the carb and pipe there are two vents marked out cut themLooks good Love the colors. Now time to drill some holes in that pretty body.
Yes +1Also check your body for possible contact with the pipe....maybe put some heat tape in those areas.
I, along with others on this forum, have had the body melt in places where it contacts the pipe.
Yip i did cut the other side it will also help with aiflow
This is Doug's buildAwesome job! Which engine did you fit? And what kind of servos?
