Smirkracing
- Reaction score
- 3
Hi All,
Just got through the first few runs with my brand new Baja 5b Flux. Here's what I am running:
- castle 2028 1100kv motor
- CNHL 9500 mah 4s packs (two of them, running in series, 8s total)
- savox 0236MG
Everything else is stock per the manual. This was my first-ever large scale RC - everything up until now has been 1/8th, 1/10th, and some mini and micro stuff as well. Luckily kit-building translated over just fine and I had a good time with the build.
Here are some of the issues I had on day 1 (and I'd greatly appreciate your help with any of these):
1. rear sway bar does not stay in place - as soon as the suspension flexes, the bar pops out from underneath the two plastic holders and then just moves around freely. I have looked at this over and over again, and I can't figure out if i'm doing something wrong. As far as I can tell, those little plastic holders don't have much chance of holding onto that sway bar rod (which has a lot of force on it). I can pry the little holders away from the mounting point with my fingernails, and the sway bar itself exerts much more force that my fingernails. As a result of this, my front inside tires lifts up a lot during turns. However, turning in general is ok, and the rear end seems pretty firmly planted. Anyone know of some beefy aluminum upgrade parts? Anyone else having this problem?
2. The battery cover is not nearly strong enough to hold the heavy batteries during rollovers and/or crashes. Does anyone make an aluminum covers? So far my batteries have ended up spilling out of the vehicle at least 3-4 times... I guess I'll learn to become a better drive, but it would be nice if the batts would stay in place.
3. Top speed: I am getting just about 50mph on grass with stock tires, per the GPS. I would have expected a little more speed with 8s on the 1100kv motor. I am running the kit-supplied 14t pinion. Motor temps are very cool (can rest my hand on the motor). Batteries are lasting about 20 min, give or take. The batteries do get quite warm. I thinking of moving to a 16 or 18 tooth pinion. Any experiences here?
4. Diff oil in rear: I used the kit oil for the diff which I think is 5k. Right now the car seems fine, but 5k seems so incredibly light for such a big vehicle. Any experiences on going thicker?
Thanks all!
- savox 0236MG
Thanks all!
