FLM extended arms
Timetoshine
Hey guys, I'm planning on buying flm extended arms for my baja, as to change these, I would like to put the rest of the pieces at the aluminum end. By cons, I'm not sure what it takes. It takes me front and rear aluminium hub and end rod I guess ? Do I need something else ? Should I buy a particular brand ?
ok...unless u really need extended ally arms I`d go for rpm`s (y)plus ally rear/front hubs..[hostile rears ..fronts.. pick any off ebay]..(y).....sum hemi ends at rear upper`s.....(y)....ally clutch housing/carrier/gear plate...turtle or vertigo...(y).......team chase rear tower supports.....(y)..turtle front/rear shox/tower support/braces...(y).......imo everything else should b left plastic..(y).....having too much all is bad esp if bashing off road......(n)......
and I do own a pretty sorted 5bss (y).....take a look below
https://www.largescaleforums.com/threads/my-hpi-26-baja-5b-ss.21475/page-7
If your doing arms, the FLM extended arms kit is worth it. Makes the baja more stable and they are very strong for aluminum
Is it normal that I can't find alloy hostile for the front ? Suggestions for the front one ?
